Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: GB poping out of gear
ryan hopkes
09-25-2012 11:58:02
i dont think its the shifting rods beacuse i fixed the detents and it helped alot but there is alot of noise from the trany
redgems
09-26-2012 07:48:33
 Re: GB poping out of gear in reply to ryan hopkes, 09-25-2012 11:58:02
This is a "U" tranny with cover off. My bearing at end of imput shaft inside larger gear was distroyed. I amagine it would of let shaft dropp and wobble. Tony
Puller1
09-25-2012 14:12:32
Doesn't sound good. Sounds like you may need to pull the top cover and look for bad bearings. There is a needle bearing that goes in the inside of the pinion shaft on the end of the top shaft that the slider gears run on.
ryan hopkes
09-26-2012 06:02:51
 Re: GB poping out of gear in reply to Puller1, 09-25-2012 14:12:32
is a u rear end the same as a gb?
TimYates
09-26-2012 10:59:37
 Re: GB poping out of gear in reply to ryan hopkes, 09-26-2012 06:02:51
yep looks identical inside
