| Author |
[Modern View]
| ryan hopkes
09-19-2012 17:59:52
96.2.96.177
i need help i got a g6 diesel that has been totaly rebuilt... im getting antifreez in the oil any ideas on what might cause this... i know there is alot of things that might cause this but any ideas on whats most likely??? i dont think its a head gasket there brand new... with reserficed heads and jugs.. |
| red bull
09-20-2012 18:55:46
208.69.227.1
Re: minneapolis moline g6 help in reply to ryan hopkes, 09-19-2012 17:59:52
| I had the same problem with mine. It was the water pump seal. |
| Blackland Dan
09-20-2012 18:08:41
216.114.61.106
| Ryan, Cliff is right about the water pump seal. It happened to me on my G6 and it would dump a lot of water into the crankcase. I'm not sure what your water problem will turn out to be, but, don't forget the water pump. A good place to get Moline parts is from Welters, 417-498-6496. |
| Howard H.
09-20-2012 13:27:04
164.58.210.23
| Yikes!Sounds like you've got a problem... Does it look like the heads have ever gotten hot?? Is the paint and/or grease burned off them?? If so, they might be cracked causing your water issue... And or caused a valve guide to seize up on the valve breaking the rocker arms... Howard
| ryan hopkes
09-20-2012 20:24:24
96.2.96.177
Re: minneapolis moline g6 help in reply to Howard H., 09-20-2012 13:27:04
| yea there rusty but the heads and jugs have been baked out when it was rebuilt but i dont think antifreez is getting in the cylinder tho beacuse its not hydro locking or no white smoke and it has brand new valvs and guides and they all seem to be good |
| MMUBMM
09-20-2012 10:56:32
38.123.14.49
| Cliff Nelson
09-19-2012 18:52:19
96.60.120.179
| Did you do anything with the water pump? I would check that first as a bad seal can put anti freeze in the oil. |
| Howard H.
09-20-2012 09:42:37
164.58.210.23
Re: minneapolis moline g6 help in reply to Cliff Nelson, 09-19-2012 18:52:19
| How much water is getting in?? I would second Cliff"s idea of checking the water pump. They are pretty prone to problems, though they typically will leak to the outside more commonly than the inside (at least on 605s & old style & HD 800s )...If it gets hot on you very quickly and/or runs hot with bubbles in the water, might have a cracked head or bad gasket... Howard |
| ryan hopkes
09-20-2012 11:48:34
96.2.96.177
Re: minneapolis moline g6 help in reply to Howard H., 09-20-2012 09:42:37
| anyone know the best place to get parts? |
| ryan hopkes
09-20-2012 11:06:13
96.2.96.177
| well i just found out there is alot more then just that to worry about... whoever rebuilt this motor had no clue what they were doing... i heard a loud clicking noise from the valve cover and i took the breather off and looked down in there and the whole rocker setup was sideways so i took the valve cover off and three push rods werent even conected to the rockers.. they have been sitting in there beating the hell out of everything and the rocker toweres are snapped right off... this motor has alot more problems then just that now.. and i never owned a 6 cylinder moline befour soo i didnt know it wasnt running right.. and since its a diesel everything makes noise soo i didnt hear it till i took the hood off and i havent even owned this tractor for a week yet.. im pist |
| ryan hopkes
09-20-2012 05:42:09
96.2.96.177
| i was thinkin about that i think im going to pull the oil pan off and clean it up the crank case and then see if it drips from anywhere do they have sleaves in that motor? |
| ugly ub
09-22-2012 06:54:26
71.35.91.223
Re: minneapolis moline g6 help in reply to ryan hopkes, 09-20-2012 05:42:09
| ryan I beleve we live close to each other reply to the email and i will give you my phone number i can help you out |
| ryan hopkes
09-23-2012 11:23:15
96.2.96.177
Re: minneapolis moline g6 help in reply to ugly ub, 09-22-2012 06:54:26
| i got it running good now it was fuel in the oil not antifreez and i think i got most of the bugs out of her for the nowthen pull next weekend thank you everyone for the help we got 3 molines and now i know where to get some great advice we got a g6, gb, and a strange u |
