Roosa Master Pump
molinegb
Do anyone know how to remove throttle shaft on Roosa Master pump? It is same as G705,706,707,708 etc. I want clean plungers and rollers. Shaft has to split into two. Appears like it is pressed. Someone said there is a c-c lip but I don't see one.
Found clip. Was actual cam. Diassembled pump,cleaned checked and reassembled. A little tricky,but once I did one I quickly did another but had to order kit for second. Another learning experience!
