Anonymous-0
I am having a serious issue with my GB but hope someone will know a simple fix.
The clutch is not slipping as I thought, what is happening is that under a load the tractor will not pull itself with the clutch engaged but when I pull back on the lever the clutch will engage. So I have to keep the clutch lever at the center area where you are half engaging and half not and the tractor will pull a 4 bottom plow all day but when you let the lever more either way just a fraction on an inch, the clutch will disengage. Any suggestions?
