| Minneapolis Moline Tractors Discussion Forum |
Topic: GB Clutch problems
[Return to Forum]
| Author |
[Modern View]
| Jim Calhoun
09-16-2012 18:34:11
24.223.98.118
I am having a serious issue with my GB but hope someone will know a simple fix. The clutch is not slipping as I thought, what is happening is that under a load the tractor will not pull itself with the clutch engaged but when I pull back on the lever the clutch will engage. So I have to keep the clutch lever at the center area where you are half engaging and half not and the tractor will pull a 4 bottom plow all day but when you let the lever more either way just a fraction on an inch, the clutch will disengage. Any suggestions? |
| MMDEL
09-19-2012 07:46:33
64.12.116.19
Re: GB Clutch problems in reply to MM diesel, 09-16-2012 18:34:11
| Hold the pin out with a small vise grip and put a drift up to the collar pointing in the direction to rotate it clokwise, and give it a whack with a hammer to break it loose. Good idea to spray some penetrating oil around the collar where the threads are the night before.
MMDEL |
| ILL John
09-18-2012 04:58:49
99.136.199.105
Re: GB Clutch problems in reply to Jim Calhoun, 09-16-2012 18:34:11
| Jim, When the clutch is disengaged the ring should turn, sometimes takes alittle force. Turn it clockwise to tighten, just like putting a nut on a bolt. |
| Albert Goerzen
09-17-2012 18:54:49
23.29.198.99
| How much effort does it take to go over center? It sounds like it just needs to be set up a notch or two. It should take a bit of force to go over center and you should feel a distinct snap as it goes in or out. If it doesnt snap, its too loose. |
| Jim Calhoun
09-17-2012 19:36:54
24.223.98.118
Re: GB Clutch problems in reply to Albert Goerzen, 09-17-2012 18:54:49
| I tried to adjust the clutch by setting it up a notch or two but first of all, do I go clockwise or counter clockwise to tighten the clutch and as I tried to move it with the pin pulled out all the way it won't budge either way. What am I doing wrong? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
