TractorLinks.com
Show Parts for Model:
Re: GB Clutch Adjustment
MMDEL
09-12-2012 08:46:35
Real simple. Take off the cover on the left where you grease the clutch shifter ring. Place trans in nutral. have the clutch released. Then rotate the clutch assy untill you see a PIN sticking out. Pull out the PIN and rotate the clutch collar and lever assy one notch and check the snap on the clutch handle when you engage the clutch. If you need more, then give it another notch. The tricky part is holding the clutch assy still while you try to move the clutch collar and hold the pin out all at the same time.
MMDEL
