U- MM with no oil press. Why??
mm585
I have a single block U thats haunting me. With the line screwed out of the block I have oil flow but no pressure. I have cleaned out the screen on the bottom of the pump, changed oil and filter. Droped the pan and changed the oil pump, changed the compleat oil filter assy, and looked for a spun bearing. I have the screw on the regulator valve bottomed out and still no pressure. Has Anyone ever ran in to this? Thanks.
I didnt know that that check ball was there, Not only was the ball stuck the spiring was rusted in half. Freed up the ball, replaced the spring and I now have 25 lbs. of oil press. at idle thanks a million!
