Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Topic: new idea for GBD puller.
[Return to Forum]
mm585
08-25-2012 19:56:10
166.182.3.69
Question. Is there a diesel head that has the same bolt pattern as an early 800 power unit? Ive never had the heads off of a diesel moline so I dont know. Thank You.
[Reply]   [No Email]
Wilberg
08-29-2012 20:23:58
67.43.115.66
 Re: new idea for GBD puller. in reply to mm585, 08-25-2012 19:56:10
Hey Mightymolinekid- I'm wanting to advance the timing on a bosch pump on a 425D with 504 jugs. Can you email me the best way to go about it?
[Reply]  [No Email]
mightymolinekid
08-30-2012 05:51:24
166.182.3.69
 Re: new idea for GBD puller. in reply to Wilberg, 08-29-2012 20:23:58
Sent you an E-mail with my number, give me a call!
[Reply]  [No Email]
mightymolinekid
08-29-2012 06:00:35
166.181.3.42
If I'm wrong I'll take a beating but here goes anyway: don't know as much about the 800 but if memory serves correct the real early ones had cast iron pistons. So I THINK you would only need to machine one hole right between the cylinders in the jug...I believe its the only one the diesels have than the gas. I know its true for a 504 and similar. A G1000 roosamaster pump would not put out enough fuel but you need that core to send to a pump shop and put a 450 head on and open up the injector tips. Also use the diesel accessory drive, you may need to change your timing gear set to mesh with the injector pump drive gear. Sound possible with a lot of digging, some head scratching and maybe a whole bunch of beer LOL!! Just my thoughts....
[Reply]  [No Email]
old fart MM puller
08-26-2012 19:17:54
166.182.3.250
If memory serves me, someone correct me if im wrong, the early 800 jugs are cast heaver than most on the top. I think you could set the jugs up in a milling machine and drill and tap the missing holes. I also beleve that you are corect on the later heads and a rossa pump (dont for get to get the lines). I feel what you need to do is find a G1000 and rob the upper end. I think the gas pistons should work as long as you dont get carried away with the fuel and timming.If Im wrong I stand corrected.
[Reply]  [No Email]
mm585
08-26-2012 09:45:15
166.182.3.209
I knew that the 800 jugs were missing some bolt holes but im wondering if the jugs can be drilled and tapped? or could we run studs all the way to the bottom? mabie use some later heads and a roosamaster pump???
[Reply]  [No Email]
kevin moschenrose
08-25-2012 22:26:04
74.34.88.198
I am thinking no. The diesel head for one takes more head bolts.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
