| Minneapolis Moline Tractors Discussion Forum |
Topic: Build a Stutgard Za
[Return to Forum]
| Author |
[Modern View]
| roadcomm
08-19-2012 07:01:43
66.87.4.252
I am considering building an articulated Za simular to a Stutgard . Does anyone have any input on how to transfer power from the power unit to the rear end? |
[Reply] [No Email] | |
| t.r.k.
08-19-2012 11:47:49
71.31.64.233
Re: Build a Stutgard Za in reply to roadcomm, 08-19-2012 07:01:43
| On the one I saw in Ohio once they used a timing belt between the power unit and the clutch shaft on the front transmission. Had a hole cut in the top of the bell housing for the belt to run through. |
| roadcomm
08-19-2012 19:08:41
66.87.2.42
Re: Build a Stutgard Za in reply to t.r.k., 08-19-2012 11:47:49
| where do you get the power connected from the front half? I would probably use a chain drive jack shaft and u-joint |
| t.r.k.
08-20-2012 19:14:01
71.31.64.233
Re: Build a Stutgard Za in reply to roadcomm, 08-19-2012 19:08:41
| | The drive to the rear transmission was through a large tube coupler that also served as the pivot point between the two transmissions. I would presume it contained a short shaft and two Universal joints between the clutch shafts of the transmissions. The gear shift on the rear transmission had been extended and the operator could probably shift it by reaching out the rear cab window. For most driving you probably only use the front transmission and only shift the rear one into gear when you really want to pull something. |
| roadcomm
08-20-2012 19:57:06
66.87.4.9
Re: Build a Stutgard Za in reply to t.r.k., 08-20-2012 19:14:01
| thanks I understand how to hook rear through the clutch input shaft But I am not shure where to get the power output from the front, pto would run to slow |
| BMG1
08-22-2012 14:24:08
174.124.202.6
Re: Build a Stutgard Za in reply to roadcomm, 08-20-2012 19:57:06
| Just a thought here. Are you possibly thinking of orienting the trans/rearends the same direction? All the ones I've seen point the trans/rearends bellhousing to bellhousing and usually flip the front ring gear over to drive the opposite direction. Maybe I'm missing your point. |
| kevin moschenrose
08-19-2012 22:45:00
74.34.88.198
| Mr. Martin in PA. built one he has had out at the shows. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
