| Minneapolis Moline Tractors Discussion Forum |
Topic: 605 diesel engine
[Return to Forum]
| Author |
[Modern View]
| MDWK40
08-10-2012 08:46:24
166.182.3.212
My 15 year old son just bought a GB diesel and he has a vision. I have a HD605 and he would like to bolt his diesel heads on and convert it to a diesel. I know some head bolt holes have to be drilled, and my 605 has the webbed jugs. has anyone ever tryed this swap? Thanks. |
| mm585
08-13-2012 10:11:09
166.182.3.144
Re: 605 diesel engine in reply to MDWK40, 08-10-2012 08:46:24
| Will we be able to safley bore the jugs to 4.75 on a diesel? If it were a gas enginge I wouldent bat an eye, but the detonation and compresion of a diesel makes me nervous. The reason I ask is because a few years ago I bought a set of 4.75 M&w pistons that the previous owner milled the dome off and had ran them in a 5 star diesel and he cracked two cylinder walls. We have the webed jugs Im not sure what he had. |
| mightymolinekid
08-13-2012 13:48:55
166.181.3.4
Re: 605 diesel engine in reply to mm585, 08-13-2012 10:11:09
| Yes just make sure you use jugs from a newer 504 or 336 diesel. Sleeves will easily fix cracked cylinder walls lol. I'm running a 4.75" bore diesel 4 cylinder. |
| minnmoman
08-12-2012 13:36:07
70.194.7.103
| Lol , i fergot my other too cents,,, 605 rods bearing, might be smaller, but a small obstical, can be easliy, remadey, if ya not a cummins man ,, i think kittycat piston is a ultamit,, ya might check into sprayin oil to up under those kittys lol.. It be tuff puller,, |
| mightymolinekid
08-12-2012 13:31:29
24.183.138.199
| minnmoman has lots of good ideas, just ask his parts yard in Wisconsin. How about Cat pistons? Those are 4.75". With a 605 crank you got 640 CID and you can run the short jugs on your original GBD crankcase. Yes go with the Roosa-Master pump, you will get way more fuel out of that than you can from the Bosch. |
| minnmoman
08-12-2012 13:08:37
70.194.7.103
| U might want to research, 605 crank ,off set grind ,, add alitttle stroke, newer m.m. Rods cummins pistons, taper the rods at the top, regrind cam , or go with a newer cam, cam grinds are a little better , look at the heads gb heads might be little tighter on compression ..maybe look for newer heads flow .more air,, gotta run a rosamaster pump run ,big head on it ,can go bigger. Pistons, may cost ya some, but will work,,jus my too cents |
| mm585
08-10-2012 18:34:24
166.182.3.52
| I forgot to mention he cant run any HD800 parts. I think he could get away with an early 800 lower end and jugs though. this tractor will be pulled in the clasic classes at 10% over factory high idle. Is there enouff cast in the top of the early 800 jugs to drill and put in the missing studs? I did get a roosa master pump and drive today but no lines. Im starting to think a 585 with the small bell from a gb gas may be the way to go. Then rework a gas flywheel?? I dont know. |
| LW
08-11-2012 05:19:41
184.3.225.69
Re: 605 diesel engine in reply to mm585, 08-10-2012 18:34:24
| Then just put a 605HD crank in a 504dhd. Use a differtent rod and piston, get up to 650-675 cid fairly easy. |
| mm585
08-10-2012 18:34:23
166.182.3.195
| Dieselbear
08-10-2012 17:55:52
50.193.137.19
| You can make one bigger than that, but not that combo |
| mm585
08-10-2012 15:10:54
166.182.3.136
| Isnt anyone going to reply? Ive often thought about this conversion also. Can it be done? |
| LW
08-10-2012 17:58:28
184.3.225.69
Re: 605 diesel engine in reply to mm585, 08-10-2012 15:10:54
| I think a HD 800 bottom and 5.400 bore cat pistons would be a great combo to do this and keep the compression in line. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
