TRM
New User
I'm in process of getting an Lp U. The owner has the engine tore down so I figure it's a good time for a build up. I'm looking for 100-200hp, and most pulls by me are 2800rpm. I think I have an idea of what I need, but any input and info on where to round up parts would be appreciated
the cheapest if your rules alow is 800 jugs and heads many association will not allow them but if yours does this is a cheap route to go g crank and this combo will give you 533 cu in and 130 hp mine is 5.25 and 7 inch stroke 606 cu in 160 hp and i run 6000 pound 5 mph 18.4.38 full cut on really hard pulling clay tracks their are many combos that will work just depends on what you are wanting to do with it
Thanks for the feedback.The 533ci is what i think i will shoot for. Did you have your pistons made?did you have to fill the blocks?
you do know you have to machine the crankcase and make studs and holes to put the 800 blocks on the u crankcase. i had a 570 cube engine built a few years back. it was strong and ran good.
No I didn't know that. Since this is my first MM build all I know is what I've read and what local MM guys have told me. Any tips or tricks that are shared would be helpfull and greatly appreciated.
