Finally going to start building my MM puller. I have a few questions.
First off I will be pulling dead weight, am I better off with the UB or UTU?
second off,
I am changing the jugs, heads, crank and cam from a GB LP. What do I do to space the jugs enough/what is the clearance I need?
Also while its apart should I get the cam ground for more power(Just want to run 93 oct. gas, and would still like it to run smooth). Any recommendations for a shop or just go to a local machine shop?
Also thinking of changing to pressed steel rims/centers. Any recommendations for tire size?
Any help is greatly appreciated.
Thanks, Chris
second off,
Thanks, Chris
