carb icing 206 gas
Anonymous-0
It was really humid at the Ilderton antique show and pull July 14&15. My Jetstar Two had a major problem with carb icing, what is the solution for carb icing in tractors? Any carb heat box from aircraft would leak too much dust for tractor use. Understand Continental powered Masseys have same problem.
Run it harder, carb icing only an issue at lower idle speeds. Never had problems with it in the field, only at shows, when not under load.
