Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Gvi LP only runs with choke on
07-05-2012 20:43:57
I'm wondering what to look at in the LP system. What I did was swap starters and took off the regulator and carb together.
It has the Ensign system and I don't see anything obvious like broken lines or hoses. It sounds OK at idle but dies when choke opens.
The starter spins the engine good now though. LOL
07-09-2012 21:49:26
 Re: Gvi LP only runs with choke on in reply to pmer, 07-05-2012 20:43:57
Thanks CC I found that the vacuum hose that goes from carb to regulator was bad and replacing did the trick.
Curt Cooke
07-09-2012 08:13:36
pmer, about the only thing you can do is put the vaporizer on your work bench, replace LP supplu with compressed air and go through the tests outlined in an IT shop manual. The carburetor, once again, adjustments according to the book, there are no real moving parts.
