UTS trans cover
I have a 1949 M&M UTS that I'm having trouble with the shifter. This tractor has the trans cover that has the solid shiftes tower. I have a chance to get a trans cover from a UT tractor, not sure of the year. This cover has the removable shifted tower. Will this cover fit on my UTS?
I'm not sure if it will fit or not but check the gear pattern cast into the cover. We switched covers on our UTU with an older cover and two of the gears were switched around. The cover works fine but have to think about which gear is where.
