injecter seals ?
have a gtbd with a diesel,once you shut the tractor off , i have small amount fuel that leaks from the injecter and runs down the block , where can i get new seals and i think there is copper washer also in there ? any help would be grateful
WE DON"T HAVE THEM IN THE RHODE ISLAND AREA , WHERE ELSE CAN TOY GET THEM ? BEEN TRYING TO CALL WENDALL EVERETT AND NOT TAKING MESSAGES
There is a dealer here
Al Preston"s Garage Inc.
810 HOWE AVENUE
SHELTON, CT, USA, 6484
Phone: (203) 924 - 1747
They are Massey but you can order anything AGCO though them.
JUST CALLED GOT THE RUN A ROUND THAT ITS A MOLINE AND THEY ARE A MASSEY PLACE BUT HE WAS COOL , SAID TO GET THE PART NUMBER AND CALL BACK SO IF ANYONE CAN HELP ME OUT WITH THE PART NUMBER PLEASE DO
(quoted from post at 14:35:19 04/25/12) JUST CALLED GOT THE RUN A ROUND THAT ITS A MOLINE AND THEY ARE A MASSEY PLACE BUT HE WAS COOL , SAID TO GET THE PART NUMBER AND CALL BACK SO IF ANYONE CAN HELP ME OUT WITH THE PART NUMBER PLEASE DO
10A3369 is the copper gasket and 10A3126 is the o-ring straight out of the AGCO Parts Book.
Tell him you are looking for parts for a Massey 95 or 97 (same as MM). If that helps him find the MM parts you are looking to buy.
The M-F part numbers are...
1001811M1 Gasket, Nozzle (1/2" ID x 3/4" Copper)
1013295M1 "O" Ring, Nozzle Holder
This is out of the 97 Diesel parts book, the 95 Diesel listed only the o-ring.
AgcoPartsBooks.com is your friend!
Hope this helps!
John
Lonewolf call welters 417 498 6496 or stamms 785 325 2720 and tell them what you need and they will send them out and your parts will be at your doorstep in a couple days! you wont need the part numbers or anything because they know what you need and you will have them faster than if you ordered them thru your agco dealer! Besides you wont have to wait for wendell to answer the phone and then act like he is doing you a big favor in getting you your parts!
Go to this website, this has the agco/massey/moline parts books. log in a a guest user. I searched for GBD but couldn't get the search to find it for some reason. It comes up if you search for a massey 95, which is the same thing. If you learn to use this resource you won't have to ask for part numbers any longer, and you can see parts breakdowns.
agco parts books
thanks for all the help, coming in from welters in a few days, thought i would list a pictures
I am interested to see what you are going to find. Neither the O ring nor the copper washer seal fuel. The only copper washer that seals fuel is the one on the cap nut. I would double check to see if the body seals to the tip. Also you said it leaks once the tractor is shut off, does it leak when it runs?
ONLY LEAKS A SMALL AMOUNT,I HAVEN'T TAKEN IT APART YET, I HOPE YOU JUST TAKE THE 2 BOLTS OFF AND THE THE INJECTER COMES RIGHT OUT OR ATLEAST THE OUTER PART SO I CAN PUT SOME NEW O RINGS IN THERE - JUST ONE OF THOSE THINGS, YOU CAN EAT OFF THIS TRACTOR AND EVERY ONCE IN AWHILE SHE'LL HAVE A SMAL STREAM COMING DOWN THE BLOCK FORM ONE INJECTER
When it leaks, does the fuel show up between the head and where the injector bolts to the head? If so, your O ring is not the problem.The purpose of the O ring is to keep dirt out, not fuel in. Got a phone number or U S mail address.
