What moline did I drag home
fireman18
today I found a deal I couldn't pass up. I drug this moline model g wheatland home and can't seem to figure out the serial number. I tried all I could to read it the best I could and all I could come up with is 0160 641 does this sound correct or am I missing a number
[/img]
According to the serial number list in the Buyer's Guide GTB 1950 serials run from 0165000001 to 01601863. Not clear when the 5 in the 4th position was dropped. looks like your are missing one digit. 01606289 was the last number in 1954
Thank you I thought I might be missing a number. The tractor is in great shape for as long as its sat except for the serial number tag
Last 0165001383; first 01601384; both were in 1950
You appear to be missing the 5th digit - as said last GTB using this s/n series was 01606289.
You may be able to place a bit closer using engine s/n tag on block. Post it and we can tell year assuming its original engine
FYI 403A4 Engine s/n break 02050001371 / 02001372
here are some pictures. The engine number is almost non existant also other than 403. The tractor serial plate has a big bold g on it and the engine plate has 403 just perfect but the numbers I care about are nearly gone.
