moline parts needed
need the gasket that goes from the axle housing to the tranmission housing. the number is ut473a
got one from welters but they are out now,so i need another one asap also matel shims ut368
let me know what you have or where i can get one of each , thanks for the help
tractor is a moline gtbd
I bet you will be making those. Old gaskets sitting in storage dry up and deform, won't fit and not many around also. Those shims did come in diff thicknesses to allow diff variations to be added together to make bearing clearances. Always best to save the old ones and handle very carefully, they can be thin!! Not sure if one could find metals to cut those out also? Maybe some machine shop has source, or maybe old printing plates might work for thicker ones. Copy the gasket for a pattern.
thanks for the feedback - already planned on doing this if its a last resort, welters had one of them, so that"s why i posted it on here and hope someone has one or knows who does, but thanjs for the feedback
According to the AGCO site, that gasket is ut463a, and the snap ring is ut473a, unless there's a mistake. Anyway, when I did mine, I just used Ultra Blue silicone for the gasket. It will move the bull gear in the thickness of the gasket, but it doesn't affect any bearing clearance. I hope there won't be a problem with that. I got lucky with the shims, so I didn't have to come up with any. I had to make a few for a Deere a few years back, and used some sheets of shim stock that I think I got from NAPA. Good luck..
I have that gasket, NOS. And I am sure I have the shims also. Give me some dimensions. OD, ID, Bolt holes number and size, bolt circle dia. And thickness you need.
MMDEL
when you get the gasket you'll find that it will be smaller and won't fit. throw it in some warm water for a while it will expand.
