rear differential ?
Looking to find instructions or a book or detailed instructions on removing a rear differential out of a gbd ? i know or at-least know the gas tank, top tranny pan, shifter have to come off ,trying to find the best way and eastiest way on doing this. Thanks for your help and happy holidays.
Having done it more times than a person should have to, I adhere to the instruction given in the IT Manual. If you don't have one, I strongly suggest you get one. That said, once you have the top off the tranny, you'll see that the next thing is going to be to remove one or the other, or both, brakes assemblies, then out it comes.
CC
JenSales? 1-800-443-0625. Or I could fax you copies of the appropriate pages if you have a fax.
CC
Check 'em to see if they have one www.link_disallowed
thank you sir - will call and try to buy one also - just got off phone , doesn;t have one for a gtbd , so i'll wait ti am for your copys- thanks a bunch
I have new IT manuals that cover all the MM models
$35 plus shipping, Call 815+456-2114
Delbert
covers removing rear differential and what nned to be done to get it out and in ? also does it give you torque spec's on all the bolts when i put it back together ?
Pull Off top, Pull off brakes, remove left seal plate, pull bull pinion shaft from housing( may have to clamp on it with something for assistance), take off rear cover, remove right bull gear nut and outer axle seal/bearing retainer. bump axle out. drop bull gear down and back at angle. Support carrier with wire across top of trans housing. now remove bull pinion gear and housing from right side. Lift carrier out!
curt, i need bearing cage for my gtbd, i think they are the same as a gbd and gb, mine is cracked and 2 pieces fell off - let me know if you or someone you know has one ? i don;t think welters carrys that
