| Author |
[Modern View]
| John from NH
06-27-2010 16:41:33
65.175.230.117
Hi All,
Went down to Connecticut to look at a Big Mo 500 today. It's really a parts tractor and I was interested in it for the engine and other large parts. It had a 206K-4 in it instead of a 206L-4. A quick search revealed that the 206K-4 belongs in a 2 Star Crawler. I took down some of the casting/part numbers off the engine and they match up with 206L-4 part numbers. The only thing I could see that was different was the oil pump configuration. The oil filter did not screw to the oil pump but instead was mounted to the side of the engine with flexible hose connecting it to the pump. This sort of makes sense if the engine had been in a crawler.
Anyways, can anyone shed any light on this engine and whether it is different in any other ways from the 206L-4? Thanks in advance for any you info you can provide!
John |
| John from NH
06-30-2010 15:51:03
65.175.230.117
Re: 206K-4 Engine in reply to usetob, 06-27-2010 16:41:33
| You'll have to point me in the right direction as I seem to be missing the link to your email.
John |
| John from NH
06-29-2010 19:04:15
65.175.230.117
Re: 206K-4 Engine in reply to LW, 06-27-2010 16:41:33
| We closed our deal earlier this evening for that Big Mo with the 206K-4 engine. I'd be happy to help you out with the cartridge filter. It will be at least another week before I get the tractor moved up here to New Hampshire. Contact me offline at jm190@metrocast.net and we can set something up.
John |
| SWMolines
06-29-2010 23:55:36
75.243.74.204
Re: 206K-4 Engine in reply to John from NH, 06-29-2010 19:04:15
| | That is great John! Ypou can contact me at my email linked to this posting.
| John from NH
06-28-2010 05:11:45
65.175.230.117
Re: 206K-4 Engine in reply to Tim Larsen, 06-27-2010 16:41:33
| I wish I could tell you what happened to the crawler. I'm sure that would be an interesting story. Probably as interesting as how two Big Mo 500s found their way to New England!
John
This post was edited by John from NH at 05:13:16 06/28/10. |
| John from NH
06-27-2010 20:06:48
65.175.230.117
Re: 206K-4 Engine in reply to Blackland Dan, 06-27-2010 16:41:33
| Thanks for ther info! I'll be in touch if we bring that tractor home.
John |
| SWMolines
06-27-2010 19:32:46
75.244.134.164
Re: 206K-4 Engine in reply to John from NH, 06-27-2010 16:41:33
| | The 206K-4 engine is basically the same motor. The only differences would be the oil pump, the rear main seal and the original water pump would have been lowered to be in the same position as on power units. If you are get the motor and would like to put an original style oil pump and filter on it, I'd be interested in getting the 206K oil filter set-up for my 2 Star. I really just need the filter and filter mounting bracket.
It would be interesting to know what happened to the 2 Star Crawler. |
| kevin moschenrose
06-27-2010 22:55:02
74.34.94.225
Re: 206K-4 Engine in reply to SWMolines, 06-27-2010 19:32:46
| That also sounds like the same set up on an MT40 mobiltow. |
| SWMolines
06-28-2010 06:17:30
75.242.243.236
Re: 206K-4 Engine in reply to kevin moschenrose, 06-27-2010 22:55:02
| | Kevin, It would not surprize me if they were nearly the same. Does the MT40 motor have a spin-on oil filter? That is what I am currently running on my 2 Star dozer and it should have the earlier cartridge filter. The set-up I am using came from a MM forklift. |
| kevin moschenrose
06-28-2010 10:22:07
74.34.94.225
Re: 206K-4 Engine in reply to SWMolines, 06-28-2010 06:17:30
| Yes, It does have that very same set up. I just got this dude a few weeks back and plan on putting it back together. Missing a few parts so I will have to make them. The only thing it is a military tug and has the 220m in it. |
