Massey Ferguson 95 Super,same as which MM Tractor
Anonymous-0
I'm looking at a Massey Ferguson 95 Super S# 17300549.......would someone know the year it was made? The ENGINE BLOCK has MM 10A14513 CAST INTO it. What is a MM GVI Engine? What is a MM G engine? So what engine does this tractor have? When I'm searching for parts what MM tractor is the same other than the badgging / tin. MM 1000? MM705?
Regards
Bob...
Bob,
You're looking at a 1960 model. It is the same as the MM GVI. The engine will have its own serial number tag and it should be a D425 model engine. If the engine has a large 4" exhaust pipe it may have been internally upgraded to a 504. This was a common upgrade back in the day by installing larger cylinders/pistons and exhaust from the later 504 engine.
Brian
Bob
The MM G engine was a 4 cyl 403 cu in disp. As noted above the GVI engine is a 6 cyl 425 cu in disp. The MM G705/6 is the same as a MF 97 tractor. and The MM G1000 is a later tractor that had the 504 cu in engine in it.
Bryce
According to the serial # you posted, your tractor is similar to the GVI diesel. The Massey 95 was similar to a GB diesel. If you have a 425 engine, the pistons (4.25" bore), could come from a stock GVI, GBD, or UB diesel. The heads, rods, etc should be interchangeable for most MM diesels. For a 504 engine, the pistons are (4.625"), and could come from a 5 star diesel, M5, M602, M670, G705, G1000, or G1050. The G900, G950, and G955 used a 4.375" piston for 451 cubic inch engine. All the above tractors had a 5 inch crankshaft. Most 6 cylinder camshafts should work in yur tractor. Though many diesel parts would fit in the engine, the GVI parts should be the closest fit. Don't hesitate to ask more questions on this board or email me directly. I have an operator manual for a GVI diesel, and a parts book for the Massey super 95.
[email protected]
