I have a 1949 MM UTS. How can I switch it ovet to 9 bolt rims :?: It has large nut to hold the hubs on the axle.
thanks howard
Pull both hubs off, grab a 9-bolt wheel, & go visit your favorite machine shop. He might need an axle to support the hubs in his lathe, but ask him first. By the way, good luck getting the hubs off. I had to take the top off my transmission & pull the axles out. I then used a 50 ton press to remove the hubs from the axles. This takes care of the hub support on the lathe!
