Brad Motheral
i have a '52 uts without hydraulics. i found a u pump and i have a few open center control valves layin around. now i need a reservoir. i found a parts g tractor with hydraulic system. will the reservoir fit my uts? can i use the reservoir as just a reservoir and pipe in my open center control valve. if so how do i plumb it? do i block off some of the pipes going in and out of the oil line flange and reroute to my o/c control valve? do i have to remove the existing control valve inside the reservoir or lock it into a float position?
thanks, brad
thanks, brad
