I had my G-VI Tachometer/speedometer restored/repaired/recalibrated by Metro Speedometer, a shop recommended to me on this forum. The drive cable assembly was damaged so I had that replaced too.
The end of the new cable that attaches to the drive bushing on the distributor housing will not go into the drive. The new cable has a punched out key on the end. The opening in the tachometer drive bushing is smaller and round, not having a key way for the new cable to insert into.
I sent the old cable in with the tachometer, but if I remember right the old cable had a square shape on the end of the cable to be inserted into the drive bushing.
What does the correct cable look like on the end that inserts into the drive bushing?
Where can I get the correct cable?
Thanks,
Dean
Thanks,
Dean
