44 special camshaft
I don't know of suppliers. Is this gas or diesel? The diesel 44 special has the same engine as the 44. In gas models, I believe only the bore was increased to raise displacement to 277. I don't think the cam specs changed. If that's the case, you may be able to use a cam from the 260 engine of a 44. Good Luck!
