Good morning guys n gals. New here and purchased a Massey F40 from a private party that him and the owner of the place where it was sitting for about 4 years stated that the hydraulics worked.. Well, NOPE. Nothing, up or down.
I flushed it with about 5gal of Diesel fuel (the old fluid was like creamed coffee) then about 10gal of tractor hyd trans fluid and still nothing.
I did a search for hydraulics and came up with 147 pages..!
Dang, did they have that many problems with thier hydraulics??
I got in touch with a 'local' Massey guy in Greneda Mississippi and he told me it was most likley the pump.
The one in the tractor does not have a filter attached and he told me that the 'newer' one with filter can be used in my application.. (I sure hope so, it cost me 400.00)
Well I pulled both of the side covers off and tried to move the actuating levers to the pump and they only move about 3/16-1/4" And that's the WHOLE swing of the adjusting levers on the outside.( draft and position levers) SO moving the whole way front or back moves it that much.. :?
I purchased the little I&T book (little is right!) but doesn't give one really that much to go on.. I tried to put the external levers in the 'adjustment' paragraph but I DON"T have the little two holes to line up the draft lever-slide.. And it states that adjusting the Master control spring has endplay with EITHER the retaining nut is too loose or too tight.. :shock: SO which one could it be? Still nothing
And it doesn't state if there are any torue specs to putting the cover plate back together. I read in a thread here that you MUST take the control arms off to put the plate back on..
Sorry for all the rambling and jumping around but What would be the first and easiest things to adjust or look for before I have to pull the old pump?
I grew up on sod farm when I was younger so I'm not afraid to jump into pulling it apart, but with kids and other obligations I'd rather not do extra work..
Thanks.. Errol
Thanks.. Errol
