Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Massey Ferguson 1105 good unit??????
K.W.
10-16-2004 08:56:18
Hi, I am going to look at a 1105 to buy. If any of you Massey guy's has any info good or bad I would like to hear it!! Thanks for your input.
megamoodairy
10-16-2004 13:58:48
 Re: Massey Ferguson 1105 good unit?????? in reply to K.W., 10-16-2004 08:56:18
They are an excellent tractor. The only problems I know of are if it has a cab don't expect the AC to work. One other problem it may have is if who ever has it ran a straight exaust pipe(turboed Perkins last much longer with a stock muffler)the engine will probably have burnt exaust valves and/or the turbo will need to be rebuilt. Other then that they are a good solid 100+ hp tractor, I'd love to have one myself someday.
holm
10-17-2004 18:38:52
 Re: Massey Ferguson 1105 good unit?????? in reply to megamoodairy, 10-16-2004 13:58:48
The MF1105 is an excellant tractor. I had one that I ran a straight pipe on at 130hp. Went to 9500hrs before the rings got so bad I had to overhaul it. Sold the tractor with over 16000hrs on it. Thought I needed a newer one. Sure miss that MF1105.
JoeMN
10-16-2004 20:54:30
If you ever do get a stock MF 1105 it won't have a turbo on it. The air conditioning probably will work(same components as similar vintage GM cars) or can be easily fixed.
Merle
10-17-2004 04:20:00
 Re: Massey Ferguson 1105 good unit?????? in reply to JoeMN, 10-16-2004 20:54:30
The 1105 came from the factory with a turbo on it as did the 1135 and 1130. The 1100 tractors and 510 combines were built without turbos.
Merle
JoeMN
10-18-2004 19:48:04
 Re: Massey Ferguson 1105 good unit?????? in reply to Merle, 10-17-2004 04:20:00
I stand corrected. The 1100 s,1130,and 1155 I have owned had very good Perkins engines. The AC problems seemed to be a compressor every couple years.
megamoodairy
10-17-2004 03:37:12
The Massey Ferguson 1105 was produced from 1973 to 1978 was rated at 110 PTO hp and 83 draw bar hp. It was powered by a turbo charged Perkins 6-354 Diesel, was available with or with out cab. It can come with a 6 speed standard transmission or the 12 speed multi-power transmission. the rated hydraulic capacity is 20 gpm at 2200psi on a closed center system. The AC lines in the cab tended to fail over time.
sibby(Aus)
10-17-2004 04:19:22
 Re: Massey Ferguson 1105 good unit?????? in reply to megamoodairy, 10-17-2004 03:37:12
Both 1105 and 1135 sold down under came standard with turbos from factory, very sweet engines.
