Loader for a Ferguson TE20
Jere Clarke
11-17-2003 14:15:40
I recently got a ferguson TE20 from my father-in-law in very good condition. I would like to get a front end loader for it with down pressure. Is this possible? If so, what would a unit like this cost? I have seen some with a pump that runs on a belt off of the engine. Is this a good idea? I would like to find a used, functional unit. Am not concerned with looks. Any advice would be appreciated.
Thanks
Jere Clarke
Roy in UK
11-18-2003 13:33:54
 Re: Loader for a Ferguson TE20 in reply to Jere Clarke, 11-17-2003 14:15:40
The idea of running a loader off a crankshaft driven pump as opposed to off the PTO or the tractors own hydraulics seems like a good idea. I have driven a "Grey Fergie" with a loader that worked off the tractors own hydraulics, the trouble is that you cannot "creep" (into a heap of soil for example ), as when you dip the clutch, the hydraulics stop. They are a bit frustrating compared with a tractor with independant hydraulics.
Alvin n Ms.
11-17-2003 17:09:42
Jere, all the loaders that I have operated had down pressure, however most have a float position at the very end of the down position, and if you pull it back a small amount it will push on down to the end of the cylinder stroke, usually picking the front wheels up off the ground. I have a 4500 Ford backhoe and loader all taken apart and can't get my wife to put it back togather. I will sell the loader for $300.00. Could be a little heavy for your TO20. alvinnms
Snowey
11-18-2003 15:32:24
 Re: Re: Loader for a Ferguson TE20 in reply to Alvin n Ms., 11-17-2003 17:09:42
What do you want for backhoe ? Are you in east coast?
Jere Clarke
11-18-2003 08:49:03
Thanks so much for your reply, Alvin. I would be interested in you loader, if it can be made to fit. Does it run off the PTO? If not, how does it work? Where are you located?
Thanks
Jere
