Mf 10 lawn tractor
ed marshall
07-17-2002 07:30:22
mf 10 type # 1446 015 204 est b&s 1 cyl hand start even thou in past might have had battery. work and starts. need picture of mower parts. have deck and pulleys and belt but is there a mid pulley or guide sheaves to rotate 90 degrees drive belt to mower.
age of tractor,has 4 spd and rev. 23 by 8.5 by 8 rear tires. b&s engine is 146402 thanks ed m
Scott DeRemer
07-28-2002 07:28:06
 Re: mf 10 lawn tractor in reply to ed marshall, 07-17-2002 07:30:22
Does your MF10 have a horizontal driveshaft? We used to sell MF lawn tractors but all of our ten's were powered by a Tecumsah. There was a small belt that ran off the right side of the engine to another jack shaft below which in turn had another belt that went to the deck Both belts were straight with no twists or turns.
ed marsahll
07-29-2002 05:56:28
 Re: Re: mf 10 lawn tractor in reply to Scott DeRemer, 07-28-2002 07:28:06
have found right mower deck with horz shaft and transmission towers. thanks. b&s was a replacement considering the age . thanks.
Scott DeRemer
07-29-2002 17:21:46
 Re: Re: Re: mf 10 lawn tractor in reply to ed marsahll, 07-29-2002 05:56:28
Good luck. Was the deck you found new or used? If new could you tell me where you found it? They have been out of production since the mid-eighties.
