I've got the Massey 65 in the shop adressing a few issues. One of which is the 3 point hitch. It bobs or adjusts itself every second or 2 when I have my mower or brush hog on it. I'm assuming I have a leak somewhere.
Tractor has the 2 spool aux control valve. When I put the valve that
controls the 3 point in the neutral or off position, the hitch seems to hold fine. When it's in position to operate, back to bobbing. With tractor off, it
will hold load fine in off position, but as soon as I move valve to the
operate position the load will drift right down.
This leads me to believe the problem isn't in the lift cylinder. I pulled
right side cover hoping to see oil spewing from an end of the standpipe,
but no such luck. I'm assuming the issue is in the pump somewhere, most
likely the control valve, but thought I'd see if there might be something
I'm missing before I start digging.
Any other possibilities before I pull stuff apart and can't troubleshoot
with tractor in one piece?
Thanks, Jeff.
Thanks, Jeff.
