Mf65 power steering is a mf165 power steering cylinder
Rkh
I added power steering on my mf65 from standard steering, getting parts where I could find them. In my previous post, I was talking about getting the top half of cylinder apart, that has 2 Allen screws next to hoses that sit on top of cylinder. Looking at different pictures, I think I have this Benton Power Steering cylinder off a mf165. I have part #2 & part #17 on my cylinder. How do I change the seals on both ends
Leave the screws in place, they don't need to come out. Use a punch in one of the holes and get it down far enough into a spool hole to keep spool from turning. Now the yoke can be turned CCW to release it from the spool. Pry the seal out, then remove the spiral groove ring inside. Spool should now come out. I use two small screwdrivers to pry out the three end cap rivets, so the O ring in the housing bore for that end of the spool can be replaced.
