ptfarmer
- Location
- San Antonio, Tx
I ran into another CAV injector problem this time on my brothers 1965 MF150, for some reason now you have to give it about 1/4 throttle every time in order for it to start. Less than 1/4 throttle it won't start, it did this without any kind of warning, it started like it normally did then the next day no start without giving it 1/4 throttle. After you start it, and move the throttle lever back to idle it will idle with no problem, it just won't start with the throttle set at idle even if you shut it off at an idle, and instantly try to restart it.
