Massey Ferguson 135 Gasser Head Studs
So I am in the process of rebuilding an old Massey Ferguson 135 that has a AG3.152 Perkins. I can't find new head studs/bolts that are listed for the gas model, although there are tons listed for diesel. Does anybody know for sure if the diesel head studs will work in a gas rebuild?
Diesel Perkins uses all fine thread hardware. Why do you want new studs? They are not torque to yield, old studs can be re-used just fine unless they are damaged.
(quoted from post at 05:16:56 09/21/18) Diesel Perkins uses all fine thread hardware. Why do you want new studs? They are not torque to yield, old studs can be re-used just fine unless they are damaged.
Thanks for the answer. And good point on the old studs. I had planned on using them if I had to, I just figured why I had it down that far if I could find new ones readily enough I would replace them. I will most likely use the old ones now, however.
