Last weekend was the first time I have been to my hunting property in WV since last November. All this rain has kept me mowing every day it's not raining. Anyway, walked up to the tractor, put the H/L in neutral, turned the key and it fired up instantly. Climbed up and drove around some. Tried to engage the PTO but it acted like the clutch wasn't in quite enough. It would disengage enough to shift, and the ground drive went in easy, but the engine drive would grind. Next I turned the engine off and was going to try and engage the PTO then start it. Nothing, and smoke started coming out of the starter solenoid. Pulled the starter and tore it down. It has a new solenoid so its good and functioning. The inside of the starter looked like a 50 year old starter. Dirty, corroded, the bendix was very stiff. We cleaned everything we could, bench tested it, and it cranked over fine. Put it back in and it started twice and hung up again. Pulled the starter and I'm going to get it rebuilt.
Back to the first question, the clutch/PTO. If you push the clutch pedal to the floor, it shifts the ground drive fine, and the transmission fine, but the engine PTO grinds and won't go into gear. If you turn the engine off, the PTO will shift into engine drive fine. Do you think the clutch needs a little more adjustment, or is something hanging up inside. The tractor has set for almost a year. Thanks, Joe.
