Year? Massey 35
I have a Massey 35 that I am trying to figure out the year as it needs some parts. The serial number plate is MIA. The tractor will run for like 3 seconds then die. It was running fine then stopped. I plan on switching it over to electronic ignition and a new coil with an internal resistor and hope that solves the problem. I just need help on the year though so I make sure I get the right parts. Thanks!
Check fuel flow, pull choke and see if that helps, don't throw parts at it. All the parts you mentioned are on this site.
