Where are the front end pivots on mf-65?
Rkh
I've read a lot about mf-65 with front loaders on them, end up with bad front end pivots. Can someone send me a picture where these are on the mf65?
(quoted from post at 10:45:15 09/18/18) Can someone send me a picture where these are on the mf65?
Not a 65 but the principal is the same , yes you can get new bushes and pivot pins and they are relatively easy to replace . The difficulty comes when the bush has worn so badly that the axle hole is ruined as Brendon mentions . If this occurs it usually means a trip to the machine shop for the axle to be bored and re bushed before a new bronze bearing bush and pin are fitted .
On the agco website, is it page 182, item #2? I tried to get picture, but wouldn't download from this website. Says not .pdf file but it is.
I built up the egg-shaped holes on mine with brazing, and painfully rounded them with a coarse rat-tail file to accept bushings.
At the same time I fitted grease fittings. Done in the late '70 s, they're still working.
