mf 35 A3.152 injector nozzle torque settings needed
Can anyone help me out with the torque settings to reinstall the diesel nozzles on the injectors? And also the injectors to head??
Also does anyone know the torque setting for the banjo bolts to each injector for the leak off fuel line?
Thanks a bunch,
Scott
Hi, don't have a figure for the nozzles and
no figure given for the drain banjos. I
always use new aluminium washers. Copper
will be ok but I think that ali is a little
bit softer. As to tightening I only nip
them up to start and check for leaks. If
all is ok I nip them up a little more.
Remember that you have a very fine thread
on a hollow bolt. It's also very easy to
cross-thread them.
DavidP, South Wales
