As title really. Followed a post I found online by DavidP about properly adjusting the brakes and it went well. Thought I would have a go at one of the the other 135's we have and noticed that how the brake rod and handbrake were attached to the arm at the rear were opposite to the one I had been working on. The one I set up properly had the brake rod attached at the top of the arm and the handbrake rod came down,passed through the end of the brake rod and attached to the bottom of the arm. This would seem to be the 'correct' way given the way the brake rod is built at that end to enable the handbrake rod to pass down through it. The other and the one down at our other dairy are attached brake rod bottom and handbrake rod top and obviously it doesn't pass through the brake rod. On the these two,the handbrake rods are sloppy as hell as they are taking a shorter route to the arm. I had a look about online for videos and pictures but that throws up both scenarios too. Is there an absolute 'correct' way?
