Hello,
I purchased a 1969/70 MF135 a couple of months ago. It was running well, but always seemed to be draining the gas slowly out of the fuel tank when parked.
Did a bunch of work with it one day and then forgot to turn off the fuel shut off valve. The fuel tank was drained and the air filter chamber was full of gas.
I figured I had a carburetor float problem. So purchased a new carb and fuel shut off sediment bowl assembly. Changed out the oil and filter, because it was full of gas.
The new sediment bowl still drips slowly even when "shut off". The carb also seems to be still running gas through it.
I am stumped, because there should be nothing else to replace for the fuel system on this tractor. Suggestions very welcome.
Thanks,
Terry
Thanks,
Terry
