(quoted from post at 08:45:36 08/10/18) Hello i have 204 massey power stearing and the top of the stearing column started leaking. i bought the repair kit with the speedy sleave and a new seal.the new seal nor the sleave fits the stearing shaft. Thanks
Thanks for the help I already removed the bearing or seal at the top of the column where can I get that at(quoted from post at 14:57:14 08/10/18) As Cary stated, the seal and sleeve go further down the steering shaft, not at the top. Just above the power steering valve.
I did mine a few weeks back, used some JB weld to hold the speedi sleeve in place as it wasn't very tight. No more leaks........at least from there. Ended up putting a new seal in the power steering pump not long thereafter.
(quoted from post at 19:20:34 08/10/18)Thanks for the help I already removed the bearing or seal at the top of the column where can I get that at(quoted from post at 14:57:14 08/10/18) As Cary stated, the seal and sleeve go further down the steering shaft, not at the top. Just above the power steering valve.
(quoted from post at 19:16:53 08/11/18) Thanks for all your help. Can you still order the top bearing number 22 or the steering column tube. Thanks were from
No I don't have any manuals.I took top bearing out before I got the kit. I called yt about my problem they couldn't help me so told me to post on this forum and someone would help me.(quoted from post at 16:15:58 08/12/18)(quoted from post at 19:16:53 08/11/18) Thanks for all your help. Can you still order the top bearing number 22 or the steering column tube. Thanks were from
Didn't you wonder why they sent you that large O ring with the seal kit? You never did say whether you had the manuals for your 204 or not.
When I got my 8N, the first thing I did was to purchase the Owners Manual, Service Manual and the Parts Manual.
I did the same when I purchased my MF202. You would be smart to do likewise. The manuals are all available here at YT.
(quoted from post at 18:06:39 08/12/18) I am i have had it for about 8 year never had any problems but I had the generator rebuilt in june. Thanks for all your help. It's been good tractor.
I ordered top bearing today im in wv i found one in texas(quoted from post at 18:15:16 08/12/18)(quoted from post at 18:06:39 08/12/18) I am i have had it for about 8 year never had any problems but I had the generator rebuilt in june. Thanks for all your help. It's been good tractor.
I'm in California so I deal with Quinn Co. They are an Agco affiliate dealer. I just give them the part number out of the parts book and they will get it for you. I've had very good luck with them.
You can probably find a dealer near you.
(quoted from post at 15:02:13 08/13/18)I ordered top bearing today im in wv i found one in texas(quoted from post at 18:15:16 08/12/18)(quoted from post at 18:06:39 08/12/18) I am i have had it for about 8 year never had any problems but I had the generator rebuilt in june. Thanks for all your help. It's been good tractor.
