TractorLinks.com
Show Parts for Model:
204 Massey
jdoates
08-10-2018 08:45:36
Hello i have 204 massey power stearing and the top of the stearing column started leaking. i bought the repair kit with the speedy sleave and a new seal.the new seal nor the sleave fits the stearing shaft. Thanks
jdoates
08-13-2018 15:17:32
 Re: 204 Massey in reply to jdoates, 08-10-2018 08:45:36
I have parts here to do it just haven't got it done yet
Caryc
08-13-2018 15:05:49
But, did you remove the outer shaft and install the sleeve and new seal yet? That's the only way, you'll stop that leak and it will only get worse with time.
jdoates
08-13-2018 15:03:24
I ordered one today thanks
jdoates
08-13-2018 15:02:13
I ordered top bearing today im in wv i found one in texas
Inno
08-13-2018 06:19:58
One more time.........this site gets a little glitchy sometimes
http://agcopartsbooks.com/PartsBooksN/Viewer/Default.aspx?
Inno
08-13-2018 06:19:16
Well that didn't work as planned. Here's the link
[/url]http://agcopartsbooks.com/PartsBooksN/Viewer/Default.aspx?
Inno
08-13-2018 06:18:33
For parts info you can also go to [/url]http://agcopartsbooks.com/PartsBooksN/Viewer/Default.aspx? and do a search. From there you can find any part number you need. That's not to say they're all still available but at least you have a starting point. I've often had luck just googling the part number or typing it in to Ebay. Sometimes you luck out on the obscure parts and someone has new old stock ones kicking around. Found a complete control valve rebuild kit for my 220 backhoe that way!
Caryc
08-12-2018 18:15:16
I'm in California so I deal with Quinn Co. They are an Agco affiliate dealer. I just give them the part number out of the parts book and they will get it for you. I've had very good luck with them.
You can probably find a dealer near you.
jdoates
08-12-2018 18:06:39
I am i have had it for about 8 year never had any problems but I had the generator rebuilt in june. Thanks for all your help. It's been good tractor.
Caryc
08-12-2018 17:59:27
If you plan on keeping that tractor, do yourself a big favor and get all the manuals. It really helps to know what's inside before you go taking something apart.
That "explosion" of the steering shaft is copied out of my parts manual. To tell you the truth, I had no idea where that bad seal was in mine before I studied the parts manual.
jdoates
08-12-2018 17:26:33
No I don't have any manuals.I took top bearing out before I got the kit. I called yt about my problem they couldn't help me so told me to post on this forum and someone would help me.
Caryc
08-12-2018 16:15:58
Didn't you wonder why they sent you that large O ring with the seal kit? You never did say whether you had the manuals for your 204 or not.
When I got my 8N, the first thing I did was to purchase the Owners Manual, Service Manual and the Parts Manual.
I did the same when I purchased my MF202. You would be smart to do likewise. The manuals are all available here at YT.
Caryc
08-11-2018 20:04:49
I doubt if you can buy that outer steering column new. You'd probably have to locate a used one.
You can order MF parts through Agco.com. Locate a dealer near you on this site.
http://www.agcocorp.com/content/agcocorp/en_US/dealer-locator.html?country=United%20States&brand=Massey%20Ferguson
If you can't read the part numbers on the page I posted try this. I don't know what browser you are using but try holding your control key and pressing your + key. This should enlarge the page with each press. Get your part numbers off that page. Use the - key to size back down.
jdoates
08-11-2018 19:16:53
Thanks for all your help. Can you still order the top bearing number 22 or the steering column tube. Thanks were from
Caryc
08-10-2018 20:36:32
There is no seal at the top, only the bearing #22
Your leaking seal is #23
[/img]
jdoates
08-10-2018 19:20:34
Thanks for the help I already removed the bearing or seal at the top of the column where can I get that at
Inno
08-10-2018 14:57:14
As Cary stated, the seal and sleeve go further down the steering shaft, not at the top. Just above the power steering valve.
I did mine a few weeks back, used some JB weld to hold the speedi sleeve in place as it wasn't very tight. No more leaks........at least from there. Ended up putting a new seal in the power steering pump not long thereafter.
Caryc
08-10-2018 11:18:32
I wish one could edit a post here. You do have the parts manual don't you? You do know exactly where that sleeve and seal go on the shaft right? You did remove the outer steering column shaft right?
Caryc
08-10-2018 11:15:26
If you look at just the seal on the parts list here on YT the 202 and the 204 use the same seal. What do you mean by the seal nor the sleeve fits? To big...to small? Give me something to go by.
Caryc
08-10-2018 11:07:35
You might check out this thread. It shows how I replaced that seal on my 202. I'm betting it's the same as mine. I got the speedy sleeve kit right here at YT.
http://forums.yesterdaystractors.com/viewtopic.php?t=1352735&highlight=power+steering
