Theoutdoorsman
My 135 Diesel was low on fluid, and making a ticking sound in the transmission area. The sound would become more noticeable when I pressed the clutch. I added some Traveler UTF from Tractor Supply, and the noise became nonexistant again, and all sounded good. Everything worked good before adding the fluid. However, now the clutch won't disengage when pressed ???? I can change all the gears just fine with the tractor off, but it just grinds when trying to put it in gear while running now. Too, I can no longer engage the PTO while running. I "can" get it into Low 1 and reverse while running, but its difficult. I tried adjusting the clutch pedal to no avail. Any suggestions would be most appreciated. By the way, my fluid looks milky white, and needs dumped/refilled, but I hate to go through the expense changing it before knowing it could be the culprit. Thanks for any advice.
