555 sediment bowl body removal
Hi fellas
Does it just thread out of the tank. Parts book doesn't give a decent illustration. Also the fuel shut off valve pictured leaks gas a little bit is there something I can do to fix it? Is there maybe some packing in behind the nut?
Thanks
john
I wasn't aware that you could get a new body. figured you could get a bowl and a gasket but not the body. Will look into it though. Thanks for the info
