Hi, i did replace the brake discs in the old 165 last fall, only on the left side and figured I would do the right side this summer. the plates were almost welded to the shaft with rust, but other than that the actuator itself didn't seem to be worn out too much so I cleaned it and reassembled it... now the problem I have since i did the brake job is that I have to nearly stand on the brake pedal to get it to brake, sometimes more than others, and nearly impossible to lock the wheel, would just like to know if it is possible to mount the actuator backwards or something? would like to have this tractor to brake as it should because this is the tractor that I use for loading logs on the sawmill, and bushhogging and I find it pretty dangerous. Thanks guys!!
