65 Massey ferguson hydraulic problems
Ddave
New User
Hi everyone I need some help I just purchased a 1963 model 65 massy ferguson the lift isn't working properly when you try to lift something it does it very slowly and jumps when you push your clutch in lift goes down and will drop all way down when you cut engine off. I changed hydraulic oil didn't help any . Would definitely appreciate any advice Thank you
Check your draft levers. Two square levers on outside. This will make
it jump. There are two marks (close top)and the levers are set between
marks. Adjust to where it works best. Push your clutch half way
down(live pto) and lift will stay up with engine running. Lift going
down after engine is off is normal with wear over the years.
