I have a problem with some grease fittings that are plugged up. The fittings are not the problem since I can remove them and pump grease through them. But when I put them back in my grease gun will just not pump anything through them.
I purchased one of those grease fitting cleaners. It's the kind you fill with penetrating oil then put on the fitting and strike it with a hammer to inject the penetrating oil. Even this does nothing. I have tried repeatedly but it doesn't work. These grease fittings are on the bottom of my front spindles. You can see one of the fittings I'm talking about in the first picture. The second picture shows the fittings on the top of the spindles. These work correctly.
The funny thing is that the parts book drawing does not show those bottom grease fittings. It only shows the top ones as you see in #3 in the last picture. Anyone have any ideas?
By the way, this is a MF202.
