How to turn up the injector pump 354 Perkins
mvvette97
New User
Hey guys I have a massey 699 with the black 354 Perkins in it. I would like to bump up the injector pump for a bit more power. I done a bit of web searching and it looks like I remove the side plate and there are two bolts to loosen up and then turn the notch one way or the other. Anybody else have any more info on this/ thanks.
Post the dispatch/model number and I'll look it up. If it's the four plunger pump like I think it is, pump has a very limited range of fuel adjustment since one check plate is fixed, and the moveable plate does not allow much change.
