steve19438
along with the hyd. filter post earlier. does a MF 50 have a hyd. filter ? if so is it accessible without taking a cover plate off ?
thanks.
Later 50 should have a filter. Early filter doesn't. You can get at the filter through the side cover. If it has multi power the screen for the MP pump will be in the way and you will have to go through the top cover.
The MF 50 and MF 35 are like "Fraternal Twins"...... the Internal Hydraulic Oil Pump:
Pictures of my MF FE 35 x Hydraulic Oil Pump adventure:
Bob...Owner operator MF FE 35 X ...and other colored Tractors:
I've only ever removed one TO-35 pump and it had no filter/screen. old style I guess. thanks for the photos.
and the purpose of the wire running across the top of pump is...?????????????????..and how important is it?
Note Picture:
As per picture. I consider the lock wire important...others may not.........
Bob....MF FE 35 X ...Tea-20 and other colored Tractors
