Slow 3 pt hitch response.
On the Massey 250 I use there's a response time of 20 to 30 seconds when I go to lift an implement. Is there something loose inside? It has new oil and is full. Thanks for your advice. Bernsy
Hi, there should be a triangular plate on the underside of the rear centre casing. This gives access to the pump filter. You'll have to drain the oil again though.
DavidP, South Wales
