Mf 65 lift cylinder
Brmf65
New User
I have a mf 65 that the lift is weak on, the lift cylinder leaks and is scarred pretty bad. The new cylinder description says takes larger studs. How would a man go about drilling the holes in the cover out? Would a hand drill be capable? Or would it be more towards a machine shop job? Thanks for any insight anybody can give!
If you decide to drill them out make sure you use a drill that is ground to drill brass and cast iron. If you use a drill ground to drill steel it will grab and possibly break the drill or mess up the hole.
